Stuxnet - US/Israeli Cyber Attack Against Iran
Dispelling pernicious myths about Islam, Muslim activists explain and discuss nonviolent spiritual resistance, the Jihad, against New World Order Totalitarianism. NATO/Mossad pseudo-Muslim 'front organisations. Exposing and eradicating the Global Web of Deceit or DAJJAL.
Moderators: Moderators, Islamic moderators
Disco_Destroyer
Post by Disco_Destroyer »
This came by way of AVG Facebook page ;)
Could be propaganda to get us ready though :(
AVG Anti-Virus This worm is really turning out to be a big deal. It is pretty sophisticated and it seems to be designed to target specific infrastructure. Is this the first of many cyber-attacks?
http://www.dailymail.co.uk/sciencetech/ ... l?ITO=1490
Computer super-virus 'targeted Iranian nuclear power station' but who made it?
By NIALL FIRTH
Last updated at 2:14 AM on 24th September 2010
The world’s first cyber ‘super weapon’ may have been designed to attack a nuclear power station in Iran, experts believe.
A computer virus called Stuxnet has been described as the most sophisticated 'worm' ever created and has already infected more than 45,000 networks worldwide.
A 'worm' is a type of computer virus that can reproduce by sending copies of itself to any PC that is connected to the infected machine.
Now internet security experts fear that Stuxnet, which was first detected in June, is the first 'worm' specifically created to target real-world infrastructure such as power stations and water plants.
The Bushehr nuclear plant may have been the target for the cyber attack, experts believe
And they say that it is so sophisticated that only a country with a high level of computer programming know-how would have been able to create it.
Many believe that it was designed to attack important industrial facilities in Iran including the Bushehr nuclear power plant which was originally due to open last month.
After it has hijacked a PC, Stuxnet looks for Siemens software that runs industrial control systems in facilities like factories and power plants.
More...
Revealed: The 'hacker' who discovered the worm that took down Twitter... a 17-year-old Australian schoolboy
http://www.dailymail.co.uk/sciencetech/ ... olboy.html
It then launches an attack by reprogramming software to give any industrial machinery new, potentially dangerous, instructions.
It is capable of taking control of key processes and is able to set off a sequence that could cause the entire system to self-destruct, say experts.
David Emm, a senior security researcher at Kaspersky, said what made Stuxnet different from other viruses was its targeted nature.
His firm has worked with Microsoft to find holes in their code which could be exploited by the worm.
Mr Emm said: What sets it apart is that it is not indiscriminate. Most viruses that are created are normally blasted out like a blunderbuss. But Stuxnet is written to only target a certain systems.
'It finds flaws in code and uses it like an open window in a house, like a jemmy to make a bigger gap', he said.
He said that Stuxnet appeared to have been designed purely for sabotage.
Ralph Langner, a German cyber-security researcher, has reverse-engineered the Stuxnet code and made his findings public. He said he is convinced the virus was designed to seek out and destroy key pieces of infrastructure.
He said: ‘Stuxnet is a 100-percent-directed cyber attack aimed at destroying an industrial process in the physical world. This is not about espionage, as some have said. This is a 100 percent sabotage attack.’
Iran was hardest hit by Stuxnet with nearly 60 per cent of all infected PCs found there.
Mr Langer believes that the Bushehr nuclear plant was the intended target for the attack.
Bushehr is currently being loaded with nuclear fuel but was not switched on in August as had been planned.
Mr Langer says that the sophistication of the virus means that only a ‘nation state’ could have developed it.
He wrote: 'With the forensics we now have it is evident and provable that Stuxnet is a directed sabotage attack involving heavy insider knowledge.
'This is not some hacker sitting in the basement of his parents' house. To me, it seems that the resources needed to stage this attack point to a nation state.'
Mr Langer also believes that Stuxnet virus has already hit its target - we just haven't heard about it yet.
Disco_Destroyer
AVG Anti-Virus Thumb drives were actually the way that the last virus got into the Pentagon - http://www.wired.com/dangerroom/2008/11 ... ans-usb-d/
They can scan, but if it is a new and specialized virus, most virus scanners won't know the signature. They will have to rely on behavioral analysis to detect it.
Disco_Destroyer
Why was this moved :0
anyway this adds weight to the propaganda analogy as it seems to have done the same to Facebook
More Details on Today's Outage
by Robert Johnson on Friday, 24 September 2010 at 01:29
Early today Facebook was down or unreachable for many of you for approximately 2.5 hours. This is the worst outage we’ve had in over four years, and we wanted to first of all apologize for it. We also wanted to provide much more technical detail on what happened and share one big lesson learned.
The key flaw that caused this outage to be so severe was an unfortunate handling of an error condition. An automated system for verifying configuration values ended up causing much more damage than it fixed.
The intent of the automated system is to check for configuration values that are invalid in the cache and replace them with updated values from the persistent store. This works well for a transient problem with the cache, but it doesn’t work when the persistent store is invalid.
Today we made a change to the persistent copy of a configuration value that was interpreted as invalid. This meant that every single client saw the invalid value and attempted to fix it. Because the fix involves making a query to a cluster of databases, that cluster was quickly overwhelmed by hundreds of thousands of queries a second.
To make matters worse, every time a client got an error attempting to query one of the databases it interpreted it as an invalid value, and deleted the corresponding cache key. This meant that even after the original problem had been fixed, the stream of queries continued. As long as the databases failed to service some of the requests, they were causing even more requests to themselves. We had entered a feedback loop that didn’t allow the databases to recover.
The way to stop the feedback cycle was quite painful - we had to stop all traffic to this database cluster, which meant turning off the site. Once the databases had recovered and the root cause had been fixed, we slowly allowed more people back onto the site.
This got the site back up and running today, and for now we’ve turned off the system that attempts to correct configuration values. We’re exploring new designs for this configuration system following design patterns of other systems at Facebook that deal more gracefully with feedback loops and transient spikes.
We apologize again for the site outage, and we want you to know that we take the performance and reliability of Facebook very seriously.
Rightly maybe should just go with the UN thread?
Seems timed to coincide with Ahmedinejad's UN speech.
Disco_Destroyer
TonyGosling wrote:Rightly maybe should just go with the UN thread?
Yea seems weird, I couldn't remember where I put it, just confused me when I wanted to add something.
Seen nothing from PressTV or RT yet so I'd say BS though really.
Especially when you've got US MSM say its Israel :0
Disco_Destroyer
http://edition.presstv.ir/detail/144245.html
Iran's nuclear chief cautions the head of UN nuclear agency that he should not allow himself to be used as a political instrument for starting a war against Tehran.
Yukiya Amano's biased approach has raised the question in Tehran about whether he is "interested in providing a pretext for an attack against us," Head of the Atomic Energy Organization of Iran (AEOI) Ali Akbar Salehi said.
"Is Amano interested in associating his own name with war? Does he want to see the world beset by catastrophe?" Salehi queried in an interview with the German weekly Der Spiegel which was published on Monday.
"It is merely a friendly, but serious, warning that one should not allow oneself to be politically instrumentalized."
Salehi said Amano had failed to ascend to the post of IAEA chairman a number of times, because "many countries were concerned that he would yield to external pressure."
"Mr. Amano must be careful not to lose his legitimacy due to his partisanship for certain policies."
Salehi stressed that while Iran is "trying to accommodate the IAEA beyond what is required by our written obligations," Amano's apparent bias had caused opposition to a "flexible cooperation" with the agency to increase in Tehran.
"We will not accept the new tone," Salehi concluded.
Amano claimed in his February 18 report on Iran, which was released amid a US campaign to win international support for adopting sanctions against Tehran, that the IAEA had "concerns about the possible existence in Iran of past or current undisclosed activities" that could enable the Iranian military to develop a nuclear bomb.
His report came while the agency had in its previous reports confirmed the non-diversion of Iran's nuclear program.
Earlier in September, Amano released his latest report in which although the "non-diversion of declared nuclear material in Iran" was once again confirmed, Tehran was urged to "cooperate in clarifying outstanding issues,” and also to “act strictly in accordance with the provisions of, and to ratify promptly, the Additional Protocol.”
He also claimed Iran's decision to bar the agency's two inspectors would "hamper the inspection process."
Iran barred two IAEA inspectors from entering the country in June on grounds that they had leaked information to the media before the official issuance of the agency's report on Iran's nuclear program.
MYA/HGH/MMN
Israeli cyber attacks target Press TV
Thu Mar 24, 2011 3:36PM
http://www.presstv.ir/detail/171502.html
Over the past 10 days, Press TV news website has been hit by Distributed Denial-of-Service Attack (DDOS) from Israeli sources.
The attacks, however, have failed to bring the site down, reportedly due to formidable security systems integrated into the website.
DDOS attack is an attempt to keep an internet site or service from functioning efficiently or at all, thus making it unavailable to its intended users.
Another popular Iran-based Arabic-language news website Al-Alam has also been the target of numerous cyber attacks from sources in Israel and a few US-backed Arab countries.
Press TV and Al-Alam news websites are among the most active and prominent independent sources for coverage of developments on the recent uprisings in Middle Eastern and North African countries.
The Iran-based websites also provide extensive coverage of events in occupied Palestinian territories.
Documents released in 2010 by Wikileaks whistleblower website revealed that Britain had concentrated its efforts on halting Press TV Ltd from producing programs critical of Western Imperialism.
In an article entitled The Secretive Campaign to Halt Press TV in the UK, British journalist and broadcaster Lauren Booth outlined UK's efforts to support the US in shutting down the company that markets documentaries and series to the Iranian channel with an identical name.
Having failed to find any legitimate problem with the quality or content of the programs produced by Press TV, the UK's National Westminster (NatWest) Bank froze Press TV Ltd's business account without any prior notice last month and stated that the accounts would be permanently closed in February 2011.
Press TV has also been put off the air in several Western-backed regional states for covering the popular uprisings in the Middle East and North of Africa.
Earlier in March, Bahrain interrupted the broadcast of Iran's Arabic-language entertainment channel iFilm, following its violent crackdown on anti-government protests in the country.
Press TV has gained popularity for its fair and in-depth coverage of the revolutions in the Middle East and North Africa, particularly in Bahrain.
Freelance journalist Johnny Miller, who covered the uprising in Bahrain for Press TV, was detained, harassed and eventually deported from the country earlier this month for no specific reason. His equipment was also confiscated by the Bahraini authorities.
http://bcfm.org.uk/wp-content/Podcasts/ ... 180001.mp3
US governor Tim Pawlenty priases the "good work" carried out by the US and Israel in assasinating Iranian nuclear sceintists and unleashing the Stuxnet worm
http://thetimesofpakistan.com/2011/10/1 ... nvoy-game/
Disco_Destroyer
Stuxnet x20: Massive cyber spy virus 'Flame' hits Iran, Israel
http://www.rt.com/news/flame-iran-virus-kaspersky-442/
Published: 29 May, 2012, 04:28
Edited: 29 May, 2012, 13:35
Video
Reuters/Stephanie McGehee
(15.0Mb)embed video
TAGS: Conflict, Scandal, SciTech, Middle East, Politics, Internet, Iran, Tom Barton, Social networks, Security
A powerful data-snatching virus targeting computers in Iran, Israel and other Middle Eastern countries has been discovered by Russian experts. The worm has been used for years for what seems to be state-sponsored cyber espionage.
Russian cyber-security company Kaspersky Lab says the malware, codenamed Flame, is the largest and one of the most complex cyber-attacks ever discovered. It reports that the most severely affected computers are in Iran – but Israel, Syria and other countries across the Middle East have also been infected.
Kaspersky's first recorded instance of Flame dates back to August 2010, although the firm admits the worm could have been stealing data for years before that. The virus may also have been built on behalf of the same nation or nations that commissioned the Stuxnet virus that affected the Iranian nuclear program in 2010.
The Moscow-based company said on Monday that its researchers had yet to determine whether Flame had a specific mission, like Stuxnet or Duqu – another massive cyber-attack that had sought to infiltrate networks and steal data.
Flame’s code appears to be twenty times the size of Stuxnet’s. The malware is able to gather data files, remotely change settings on computers, turn on PC microphones or webcams in order to record conversations and video, take screen shots – and eventually send the data back to the attackers.
"Once a system is infected, Flame begins a complex set of operations, including sniffing the network traffic, taking screenshots, recording audio conversations, intercepting the keyboard, and so on," Kaspersky's chief malware expert Vitaly Kamlyuk told BBC.
The complexity of the virus and the targets that have been hit led Kaspersky Lab to believe that this a government is behind the cyber attacks. At the same time, the experts are not sure of its exact origins and have yet to determine whether Flame had a specific mission, like Stuxnet, whose attack Iran blamed on the United States and Israel.
US: 'No comment’
Many experts believe Iran’s suspicions toward the US and Israel are not without merit. In January 2011, The New York Times came out with a report stating that both attacks originated from a joint program in 2004 aimed at undermining Iran's alleged efforts to build a nuclear bomb. The article said the program was authorized by US President George W. Bush, and later accelerated by his successor, Barack Obama.
A spokesman for the US Department of Defense, David Oten, declined to comment on Flame on Monday, Reuters reports. The CIA, State Department, National Security Agency, and US Cyber Command declined to comment as well.
Kaspersky Lab said it discovered Flame after a UN telecommunications body asked it to analyze data on malicious software across the Middle East in search of the data-wiping virus reported by Iran.
Israel hints it may be behind 'Flame' super-virus targeting Iran
'Flame' cyber attacks that can steal vast amounts of sensitive data come as Tehran nuclear talks falter
Donald Macintyre , Jerome Taylor Wednesday 30 May 2012
A top Israeli minister yesterday fed speculation that the Jewish state could be responsible for a powerful new virus said to have been used in a fresh attack on computers in Iran and elsewhere in the Middle East.
The discovery of the unprecedented complex data-stealing "Flame" virus was disclosed by a Russian-based digital security firm Kaspersky Lab. Its experts reported on Monday that it had been applied most actively in Iran, but also in Israel and the occupied Palestinian territories, Sudan, Syria, Lebanon, Saudi Arabia and Egypt.
Moshe Yaalon, Israel's Vice Prime Minister and Strategic Affairs Minister, told the country's Army Radio: "Anyone who sees the Iranian threat as a significant threat – it's reasonable [to assume] that he will take various steps, including these, to harm it."
Mr Yaalon, a former military Chief of Staff, added: "Israel was blessed as being a country rich with high-tech. These tools that we take pride in open up all kinds of opportunities for us."
He stopped short of directly claiming responsibility, but Israel has long been in the forefront of opposition to Iran's nuclear programme, currently the subject of difficult negotiations between Tehran and six world powers.
Although many viruses can already steal large amounts of data, few have been as comprehensive as Flame, or steal in so many different ways. The security industry is still in the early stages of examining what exactly Flame can do, but examples already given include hijacking a computer's microphone to record conversations, taking screen shots during chats through instant messenger and even stealing data from devices that are attached to an infected computer through a Bluetooth connection.
The Flame virus is believed to the third and, at least in information gathering, most effective cyber attack on Iranian computer systems in recent years. Tehran admitted the best known of these, Stuxnet, had damaged centrifuges at its uranium enrichment plant in Natanz in 2010.
The internet security industry has been both shocked and impressed by Flame's complexity and how dedicated it is to stealing as much intelligence data from a computer network as possible. Rik Ferguson, director of security research at Trend Micro, told The Independent: "It's a very comprehensive and bespoke piece of malware. It's further evidence that certain states or organisations are using malware to deliver very effective targeted attacks that can only be developed with significant planning and resources."
There are disagreements over how long it has been in existence. Kaspersky say the attacks began around 2010, but analysts at Budapest University's renowned Cryptography and System Security, which has also been analysing the virus since March, say evidence suggests Flame may have been infiltrating computer systems for five years.
Iran has largely played down its vulnerability to cyber attack, which it regards as part of a continued campaign by Israel and the US against its nuclear programme. It also blames those states for targeted assassinations of nuclear scientists. Officials at Iran's communications and technology ministry said yesterday they had produced an antivirus capable of identifying and removing the new malware, although many security analysts question such claims.
Mr Yaalon also yesterday voiced Israeli government scepticism about the ongoing negotiations with Tehran, saying last week's inconclusive talks in Baghdad "yielded no significant achievement" except to let Iran buy time. Talks will resume in Moscow next month.
The talks have so far faltered on Iran's resistance to demands for an end to higher grade 20 per cent uranium enrichment unless the West first eases sanctions which are due to be tightened significantly at the end of June.
http://www.independent.co.uk/news/world ... 00935.html
Disco_Destroyer
US cyberwar virus aimed at Iran, infects Chevron accidentally
November 9, 2012
http://rt.com/usa/news/stuxnet-chevron-cyber-virus-348/
America’s cyberwar is already seeing collateral damage, and it’s hitting the country’s own billion-dollar companies. Oil giants Chevron say the Stuxnet computer virus made by the US to target Iran infected their systems as well.
California-based Chevron, a Fortune 500 company that’s among the biggest corporations in the world, admits this week that they discovered the Stuxnet worm on their systems back in 2010. Up until now, Chevron managed to make their finding a well-kept secret, and their disclosure published by the Wall Street Journal on Thursday marks the first time a US company has come clean about being infected by the virus intended for Iran’s nuclear enrichment program. Mark Koelmel of the company’s earth sciences department says that they are likely to not be the last, though.
“We’re finding it in our systems and so are other companies,” says Koelmel. “So now we have to deal with this.”
Koelmel claims that the virus did not have any adverse effects on his company, which generated a quarter of a trillion dollars in revenue during 2011. As soon as Chevron identified the infection, it was taken care of immediately, he says. Other accidental targets might not be so lucky though, and the computer worm’s complex coding means it might be a while before anyone else becomes aware of the damage.
“I don’t think the US government even realized how far it had spread,” Koelmel adds.
Discovered in 2010, the Stuxnet worm was reported with all but certainty to be the creation of the United States, perhaps with the assistance of Israel, to set back Iran’s nuclear enrichment program as a preemptive measure against an eventual war. Only as recently as this June, however, American officials with direct knowledge of the worm went public with Uncle Sam’s involvement.
In a June 2012 article published by The New York Times, government agents with direct knowledge of Stuxnet claimed that first President George W. Bush, then Barack Obama, oversaw the deployment of the worm as part of a well-crafted cyberassault on Iran. Coupled with another malicious program named Flame and perhaps many more, Stuxnet was waged against Iran as part of an initiative given the codename “Olympic Games.” Rather than solely stealing intelligence through use of computer coding, the endeavor was believed to be the first cyberattack that intended to cause actual hard damage.
“Previous cyberattacks had effects limited to other computers,” Michael Hayden, the former chief of the CIA, explained to the Times earlier this year. “This is the first attack of a major nature in which a cyberattack was used to effect physical destruction.”
On the record, the federal government maintains ignorance on the subject of Stuxnet. With American companies perhaps soon coming out of the woodwork to discuss how they were hit, though, the White House may have to finally admit that they’ve had direct involvement.
After the Times published their expose in June, Senator Dianne Feinstein, chairwoman of Intelligence Committee, called for an investigation to track down how the media was first made aware of America’s involvement in Olympic Games.
"I am deeply disturbed by the continuing leaks of classified information to the media, most recently regarding alleged cyber efforts targeting Iran's nuclear program,” Feinstein said through a statement at the time. “I made it clear that disclosures of this type endanger American lives and undermine America's national security."
When Feinstein spoke to DC’s The Hill newspaper, she said, "the leak about the attack on Iran's nuclear program could 'to some extent' provide justification for copycat attacks against the United States." According to the chairwoman, "This is like an avalanche. It is very detrimental and, candidly, I found it very concerning. There's no question that this kind of thing hurts our country."
Just last month, a shadowy Iranian-based hacking group called The Qassam Cyber Fighters took credit for launching a cyberattack on the servers of Capital One Financial Corp. and BB&T Corp., two of the biggest names in the American banking industry. Days earlier, Google informed some of its American users that they may be targeted in a state-sponsored cyberattack from abroad, and computer experts insist that these assaults will only intensify over time.
“We absolutely have seen more activity from the Middle East, and in particular Iran has been increasingly active as they build up their cyber capabilities,” CrowdStrike Security President George Kurtz told the Times.
Speaking of the accidental impact Stuxnet could soon have in the US, Chevron’s Koelmel tells the Journal, "I think the downside of what they did is going to be far worse than what they actually accomplished.
Retired US general 'may have leaked Stuxnet cyberattack details'
A senior US general is believed to be under investigation for allegedly leaking details of a secret cyberattack on Iran.
http://www.telegraph.co.uk/news/worldne ... tails.html
By Jon Swaine, New York - 2:18PM BST 28 Jun 2013
James Cartwright, who was the US military's second-highest-ranking officer before retiring in 2011, is said to be the target of an inquiry by the US justice department into how the media obtained information on the Stuxnet strike on Iranian nuclear facilities.
The computer virus, which is believed to have been unleashed by US and Israeli engineers in 2010, temporarily disabled 1,000 centrifuges within Iran’s nuclear programme.
The New York Times last year published a detailed account, sourced to anonymous officials, of how the virus was developed.
It was reported to have been part of a wider cyber-attack codenamed Olympic Games, which began under former president George W Bush and was extended under President Barack Obama.
Gen. Cartwright, 63, was credited in the front-page article with overseeing the operation. He has now received a letter from justice department officials informing him that he is the subject of the leak inquiry, according to NBC News.
The 63-year-old is the highest-profile official so far to be targeted by an aggressive crackdown on leakers by Mr Obama’s administration, which has prosecuted more people under the espionage act than all past administrations combined.
Inquiries into two other leaks have seen phone records seized for reporters from the Associated Press and emails obtained from a journalist for Fox News, prompting fierce criticism of the administration from American media organisations.
The disclosures in The New York Times’s article were excerpted from a book by David Sanger, one of its correspondents, titled Confront and Conceal.
The book also contained several other inside accounts of the administration’s national security operations.
Sanger wrote that his reports were “based on interviews over the past 18 months with current and former American, European and Israeli officials involved in the programme”, adding: “None would allow their names to be used because the effort remains highly classified”.
Its leak prompted furious accusations from Republicans that Mr Obama’s aides had deliberately released information to the media in order to bolster his credentials as commander-in-chief and improve his chances of securing re-election in last November’s presidential poll.
Gen Cartwright, a 40-year veteran of the Marines, served as deputy chairman of the joint chiefs of staff between 2007 and 2011.
He was at one stage one of Mr Obama’s most trusted advisers and was once viewed as the likely front-runner for promotion to chairman of the joint chiefs of staff - America’s most senior officer.
However he is said to have fallen foul of colleagues by discreetly siding with Joe Biden, the Vice-President, during Mr Obama’s 2010 review of the war in Afghanistan. While other top generals, such as David Petraeus, then commander of US forces in the conflict, wanted a boost in US troop numbers, Mr Biden urged the president to hasten America’s withdrawal.
The chairmanship eventually went to Gen Martin Dempsey, the former chief of staff of the Army. Gen Cartwright now serves as a chair in defence policy studies at the Center for Strategic and International Studies, a Washington think-tank.
If indicted and convicted under the espionage act, Gen Cartwright could face a lengthy prison sentence. Gen Cartwright could not be reached for comment. His attorney told NBC News: “I have no comment”.
http://www.bcfmradio.com/wp-content/Pod ... 170001.mp3
http://www.bcfmradio.com/wp-content/Pod ... 180001.mp3
GCHQ intel used to develop Stuxnet, claims new documentary
US peppered Iran with thousands of cyberwar weapons
http://www.theregister.co.uk/2016/02/17 ... s_program/
17 Feb 2016 at 08:21, Darren Pauli
The super worm known as Stuxnet was but a cog in an active US war program in which hundreds of thousands of network implants and backdoors in Iran networks were actively maintained to facilitate a devastating barrage of hacking attacks, a documentary claims.
Zero Days, due to screen at the Berlin Film Festival today, claims that Stuxnet was just one part of an operation called "Olympic Games" that is itself part of a wider effort dubbed "Nitro Zeus" that involves hundreds of US defence personnel.
Nitro Zeus may also involve Israel, the film alleges.
Reports from those who've seen or been briefed on the film suggest it alleges that Stuxnet's authors attempted to keep the program covert by restricting the malware to infect only Iranian machines.
Forte Mead hackers worked furiously to mop-up infected computers after a leak became apparent.
Israeli counterparts reportedly screwed the pooch when they later unleashed a more aggressive and noisier version of Stuxnet that infected thousands of computers across more than 115 countries.
The worm was soon discovered in 2010 and promptly analysed - and gaped at askance - by the security industry and media.
The film asserts that Stuxnet contained four zero day vulnerabilities and was precision-designed for the Natanz facility using intelligence supplied by Britain's GCHQ.
It is not stated in the documentary whether the GCHQ had knowledge of Nitro Zeus, a fact that could breach national laws regarding use of intelligence material in that country.
US State Department and National Security Agency officials expressed concern over the likelihood that Nitro Zeus would devastate civilian infrastructure.
One unnamed source said Nitro Zeus planners had "no f**king clue" regarding the potential impacts of the attacks.
Former CIA and NSA director Michael Hayden says while he had no knowledge of Nitro Zeus the program has prematurely legitimised state-backed network centric warfare before rules of engagement could be agreed.
Disco_Destroyer
So now wikileaks PBGary e-mail leaks confirm what we knew ;)
https://sputniknews.com/us/201611291047 ... al-prison/
US journalist Barrett Brown imprisoned for five years for the alleged hack of the Stratfor server has been released, Edward Snowden wrote on his Twitter.
Meanwhile, Wikileaks released over 60,000 emails from US private intelligence firm HBGary to celebrate Brown's release.
https://wikileaks.org/hbgary-emails/emailid/2282
Israel Tests on Worm Called Crucial in Iran Nuclear Delay
January 15, 2011 Israel Tests on Worm Called Crucial in Iran Nuclear Delay By WILLIAM J. BROAD, JOHN MARKOFF and DAVID E. SANGER This article is by William J. Broad, John Markoff and David E. Sanger. The Dimona complex in the Negev desert is famous as the heavily guarded heart of_Israel_ (http://topics.nytimes.com/top/news/inte ... ne=nyt-geo) s never-acknowledged nuclear arms program, where neat rows of factories make atomic fuel for the arsenal. Over the past two years, according to intelligence and military experts familiar with its operations, Dimona has taken on a new, equally secret role as a critical testing ground in a joint American and Israeli effort to undermine_Iran_ (http://topics.nytimes.com/top/news/inte ... ne=nyt-geo) s efforts to make a bomb of its own. Behind Dimonas barbed wire, the experts say, Israel has spun nuclear centrifuges virtually identical to Irans at Natanz, where Iranian scientists are struggling to enrich uranium. They say Dimona tested the effectiveness of the_Stuxnet_ (http://topics.nytimes.com/top/reference ... classifier) computer worm, a destructive program that appears to have wiped out roughly a fifth of Irans nuclear centrifuges and helped delay, though not destroy, Tehrans ability to make its first nuclear arms. To check out the worm, you have to know the machines, said an American expert on nuclear intelligence. The reason the worm has been effective is that the Israelis tried it out. Though American and Israeli officials refuse to talk publicly about what goes on at Dimona, the operations there, as well as related efforts in the United States, are among the newest and strongest clues suggesting that the virus was designed as an American-Israeli project to sabotage the Iranian program. In recent days, the retiring chief of Israels Mossad intelligence agency, Meir Dagan, and Secretary of State_Hillary Rodham Clinton_ (http://topics.nytimes.com/top/reference ... nton/index .html?inline=nyt-per) separately announced that they believed Irans efforts had been set back by several years. Mrs. Clinton cited American-led sanctions, which have hurt Irans ability to buy components and do business around the world. The gruff Mr. Dagan, whose organization has been accused by Iran of being behind the deaths of several Iranian scientists, told the Israeli Knesset in recent days that Iran had run into technological difficulties that could delay a bomb until 2015. That represented a sharp reversal from Israels long-held argument that Iran was on the cusp of success. The biggest single factor in putting time on the nuclear clock appears to be Stuxnet, the most sophisticated cyberweapon ever deployed. In interviews over the past three months in the United States and Europe, experts who have picked apart the computer worm describe it as far more complex and ingenious than anything they had imagined when it began circulating around the world, unexplained, in mid-2009. Many mysteries remain, chief among them, exactly who constructed a computer worm that appears to have several authors on several continents. But the digital trail is littered with intriguing bits of evidence. In early 2008 the German company Siemens cooperated with one of the United States premier national laboratories, in Idaho, to identify the vulnerabilities of computer controllers that the company sells to operate industrial machinery around the world and that American intelligence agencies have identified as key equipment in Irans enrichment facilities. Seimens says that program was part of routine efforts to secure its products against cyberattacks. Nonetheless, it gave the Idaho National Laboratory which is part of the Energy Department, responsible for Americas nuclear arms the chance to identify well-hidden holes in the Siemens systems that were exploited the next year by Stuxnet. The worm itself now appears to have included two major components. One was designed to send Irans nuclear centrifuges spinning wildly out of control. Another seems right out of the movies: The computer program also secretly recorded what normal operations at the nuclear plant looked like, then played those readings back to plant operators, like a pre-recorded security tape in a bank heist, so that it would appear that everything was operating normally while the centrifuges were actually tearing themselves apart. The attacks were not fully successful: Some parts of Irans operations ground to a halt, while others survived, according to the reports of international nuclear inspectors. Nor is it clear the attacks are over: Some experts who have examined the code believe it contains the seeds for yet more versions and assaults. Its like a playbook, said Ralph Langner, an independent computer security expert in Hamburg, Germany, who was among the first to decode Stuxnet. Anyone who looks at it carefully can build something like it. Mr. Langner is among the experts who expressed fear that the attack had legitimized a new form of industrial warfare, one to which the United States is also highly vulnerable. Officially, neither American nor Israeli officials will even utter the name of the malicious computer program, much less describe any role in designing it. But Israeli officials grin widely when asked about its effects. Mr. Obama s chief strategist for combating weapons of mass destruction, Gary Samore, sidestepped a Stuxnet question at a recent conference about Iran, but added with a smile: Im glad to hear they are having troubles with their centrifuge machines, and the U.S. and its allies are doing everything we can to make it more complicated. In recent days, American officials who spoke on the condition of anonymity have said in interviews that they believe Irans setbacks have been underreported. That may explain why Mrs. Clinton provided her public assessment while traveling in the Middle East last week. By the accounts of a number of computer scientists, nuclear enrichment experts and former officials, the covert race to create Stuxnet was a joint project between the Americans and the Israelis, with some help, knowing or unknowing, from the Germans and the British. The projects political origins can be found in the last months of the Bush administration. In January 2009,_The New York Times reported_ (http://www.nytimes.com/2009/01/11/washi ... 02009%20sa nger%20bush%20natanz&st=cse) that Mr. Bush authorized a covert program to undermine the electrical and computer systems around Natanz, Irans major enrichment center._President Obama_ (http://topics.nytimes.com/top/reference ... ne=nyt-per) , first briefed on the program even before taking office, sped it up, according to officials familiar with the administrations Iran strategy. So did the Israelis, other officials said. Israel has long been seeking a way to cripple Iran s capability without triggering the opprobrium, or the war, that might follow an overt military strike of the kind they conducted against nuclear facilities in Iraq in 1981 and Syria in 2007. Two years ago, when Israel still thought its only solution was a military one and approached Mr. Bush for the bunker-busting bombs and other equipment it believed it would need for an air attack, its officials told the White House that such a strike would set back Irans programs by roughly three years. Its request was turned down. Now, Mr. Dagans statement suggests that Israel believes it has gained at least that much time, without mounting an attack. So does the Obama administration. For years, Washingtons approach to Tehrans program has been one of attempting to put time on the clock, a senior administration official said, even while refusing to discuss Stuxnet. And now, we have a bit more. Finding Weaknesses Paranoia helped, as it turns out. Years before the worm hit Iran, Washington had become deeply worried about the vulnerability of the millions of computers that run everything in the United States from bank transactions to the power grid. Computers known as controllers run all kinds of industrial machinery. By early 2008, the_Department of Homeland Security_ (http://topics.nytimes.com/top/reference ... tment/inde x.html?inline=nyt-org) had teamed up with the Idaho National Laboratory to study a widely used Siemens controller known as P.C.S.-7, for Process Control System 7. Its complex software, called Step 7, can run whole symphonies of industrial instruments, sensors and machines. The vulnerability of the controller to cyberattack was an open secret. In July 2008, the Idaho lab and Siemens teamed up on_a PowerPoint presentation_ (http://graphics8.nytimes.com/packages/p ... e/NSTB.pdf) on the controllers vulnerabilities that was made to a conference in Chicago at Navy Pier, a top tourist attraction. Goal is for attacker to gain control, the July paper said in describing the many kinds of maneuvers that could exploit system holes. The paper was 62 pages long, including pictures of the controllers as they were examined and tested in Idaho. In a statement on Friday, the Idaho National Laboratory confirmed that it formed a partnership with Siemens but said it was one of many with manufacturers to identify cybervulnerabilities. It argued that the report did not detail specific flaws that attackers could exploit. But it also said it could not comment on the laboratorys classified missions, leaving unanswered the question of whether it passed what it learned about the Siemens systems to other parts of the nations intelligence apparatus. The presentation at the Chicago conference, which recently disappeared from a Siemens Web site, never discussed specific places where the machines were used. But Washington knew. The controllers were critical to operations at Natanz, a sprawling enrichment site in the desert. If you look for the weak links in the system, said one former American official, this one jumps out. Controllers, and the electrical regulators they run, became a focus of sanctions efforts. The trove of State Department cables made public by _WikiLeaks_ (http://topics.nytimes.com/top/reference ... ne=nyt-org) describes urgent efforts in April 2009 to stop a shipment of Siemens controllers, contained in 111 boxes at the port of Dubai, in the United Arab Emirates. They were headed for Iran, one cable said, and were meant to control uranium enrichment cascades the term for groups of spinning centrifuges. Subsequent cables showed that the United Arab Emirates blocked the transfer of the Siemens computers across the Strait of Hormuz to Bandar Abbas, a major Iranian port. Only months later, in June, Stuxnet began to pop up around the globe. The Symantec Corporation, a maker of computer security software and services based in Silicon Valley, snared it in a global malware collection system. The worm hit primarily inside Iran, Symantec reported, but also in time appeared in India, Indonesia and other countries. But unlike most malware, it seemed to be doing little harm. It did not slow computer networks or wreak general havoc. That deepened the mystery. A Dual Warhead No one was more intrigued than Mr. Langner, a former psychologist who runs a small computer security company in a suburb of Hamburg. Eager to design protective software for his clients, he had his five employees focus on picking apart the code and running it on the series of Siemens controllers neatly stacked in racks, their lights blinking. He quickly discovered that the worm only kicked into gear when it detected the presence of a specific configuration of controllers, running a set of processes that appear to exist only in a centrifuge plant. The attackers took great care to make sure that only their designated targets were hit, he said. It was a marksmans job. For example, one small section of the code appears designed to send commands to 984 machines linked together. Curiously, when international inspectors visited Natanz in late 2009, they found that the Iranians had taken out of service a total of exactly 984 machines that had been running the previous summer. But as Mr. Langner kept peeling back the layers, he found more what he calls the dual warhead. One part of the program is designed to lie dormant for long periods, then speed up the machines so that the spinning rotors in the centrifuges wobble and then destroy themselves. Another part, called a man in the middle in the computer world, sends out those false sensor signals to make the system believe everything is running smoothly. That prevents a safety system from kicking in, which would shut down the plant before it could self-destruct. Code analysis makes it clear that Stuxnet is not about sending a message or proving a concept, Mr. Langner later wrote. It is about destroying its targets with utmost determination in military style. This was not the work of hackers, he quickly concluded. It had to be the work of someone who knew his way around the specific quirks of the Siemens controllers and had an intimate understanding of exactly how the Iranians had designed their enrichment operations. In fact, the Americans and the Israelis had a pretty good idea. Testing the Worm Perhaps the most secretive part of the Stuxnet story centers on how the theory of cyberdestruction was tested on enrichment machines to make sure the malicious software did its intended job. The account starts in the Netherlands. In the 1970s, the Dutch designed a tall, thin machine for enriching uranium. As is well known,_A. Q. Khan_ (http://topics.nytimes.com/top/reference ... qadeer_kha n/index.html?inline=nyt-per) , a Pakistani metallurgist working for the Dutch, stole the design and in 1976 fled to Pakistan. The resulting machine, known as the P-1, for Pakistans first-generation centrifuge, helped the country get the bomb. And when Dr. Khan later founded an atomic black market, he illegally sold P-1s to Iran, Libya, and North Korea. The P-1 is more than six feet tall. Inside, a rotor of aluminum spins uranium gas to blinding speeds, slowly concentrating the rare part of the uranium that can fuel reactors and bombs. How and when Israel obtained this kind of first-generation centrifuge remains unclear, whether from Europe, or the Khan network, or by other means. But nuclear experts agree that Dimona came to hold row upon row of spinning centrifuges. Theyve long been an important part of the complex, said Avner Cohen, author of The Worst-Kept Secret (2010), a book about the Israeli bomb program, and a senior fellow at the Monterey Institute of International Studies. He added that Israeli intelligence had asked retired senior Dimona personnel to help on the Iranian issue, and that some apparently came from the enrichment program. I have no specific knowledge, Dr. Cohen said of Israel and the Stuxnet worm. But I see a strong Israeli signature and think that the centrifuge knowledge was critical. Another clue involves the United States. It obtained a cache of P-1s after Libya gave up its nuclear program in late 2003, and the machines were sent to the Oak Ridge National Laboratory in Tennessee, another arm of the Energy Department. By early 2004, a variety of federal and private nuclear experts assembled by the_Central Intelligence Agency_ (http://topics.nytimes.com/top/reference ... tml?inline =nyt-org) were calling for the United States to build a secret plant where scientists could set up the P-1s and study their vulnerabilities. The notion of a test bed was really pushed, a participant at the C.I.A. meeting recalled. The resulting plant, nuclear experts said last week, may also have played a role in Stuxnet testing. But the United States and its allies ran into the same problem the Iranians have grappled with: the P-1 is a balky, badly designed machine. When the Tennessee laboratory shipped some of its P-1s to England, in hopes of working with the British on a program of general P-1 testing, they stumbled, according to nuclear experts. They failed hopelessly, one recalled, saying that the machines proved too crude and temperamental to spin properly. Dr. Cohen said his sources told him that Israel succeeded with great difficulty in mastering the centrifuge technology. And the American expert in nuclear intelligence, who spoke on the condition of anonymity, said the Israelis used machines of the P-1 style to test the effectiveness of Stuxnet. The expert added that Israel worked in collaboration with the United States in targeting Iran, but that Washington was eager for plausible deniability. In November, the Iranian president,_Mahmoud Ahmadinejad_ (http://topics.nytimes.com/top/reference ... index.html ?inline=nyt-per) , broke the countrys silence about the worms impact on its enrichment program, saying a cyberattack had caused minor problems with some of our centrifuges. Fortunately, he added, our experts discovered it. The most detailed portrait of the damage comes from the Institute for Science and International Security, a private group in Washington. Last month, it issued a lengthy Stuxnet report that said Irans P-1 machines at Natanz suffered a series of failures in mid- to late 2009 that culminated in technicians taking 984 machines out of action. The report called the failures a major problem and identified Stuxnet as the likely culprit. Stuxnet is not the only blow to Iran. Sanctions have hurt its effort to build more advanced (and less temperamental) centrifuges. And last_January_ (http://www.nytimes.com/2010/01/13/world ... 3iran.html) , and again in_November_ (http://www.nytimes.com/2010/11/30/world ... ehran.html) , two scientists who were believed to be central to the nuclear program were killed in Tehran. The man widely believed to be responsible for much of Irans program, Mohsen Fakrizadeh, a college professor, has been hidden away by the Iranians, who know he is high on the target list. Publicly, Israeli officials make no explicit ties between Stuxnet and Iran s problems. But in recent weeks, they have given revised and surprisingly upbeat assessments of Tehrans nuclear status. A number of technological challenges and difficulties have beset Irans program, Moshe Yaalon, Israels minister of strategic affairs, told Israeli public radio late last month. The troubles, he added, have postponed the timetable.
https://wikileaks.org/hbgary-emails/emailid/70623
Re: watch stuxnet do it's work on a PLC
To: greg@hbgary.com
Date: 2010-12-10 16:26
Subject: Re: watch stuxnet do it's work on a PLC
Evil. Pure Evil. I cant help but cringe when I think at all the critical
systems that are controlled by PLC's. Could you imagine if someone managed
to apply this attack inside of a large commercial or military airplane
manufacturer? We'd probably lose multiple planes before anyone even had a
chance of figuring it out, especially if the failure emulation was a very
rare proc (1 in 10000 or more)
On Fri, Dec 10, 2010 at 8:16 AM, Greg Hoglund <greg@hbgary.com> wrote:
> Forward to 3:16 in this video to see Stuxnet infect a PLC and cause
> some damage. This pretty much sums up what Stuxnet is doing inside
> factories right now.
> http://www.youtube.com/watch?v=cf0jlzVCyOI
> -Greg
[/quote]
