Liquid nuclear power: molten salt or liquid fluoride thorium
Post new topic   Reply to topic    9/11, 7/7 & the War on Freedom Forum Index -> General
PostPosted: Fri Nov 09, 2018 12:58 am    Post subject: Liquid nuclear power: molten salt or liquid fluoride thorium Reply with quote
Molten Salt Reactors(Updated July 2018)
Molten salt reactors operated in the 1960s.
They are seen as a promising technology today principally as a thorium fuel cycle prospect or for using spent LWR fuel.
A variety of designs is being developed, some as fast neutron types.
Global research is currently led by China.
Some have solid fuel similar to HTR fuel, others have fuel dissolved in the molten salt coolant.
http://www.world-nuclear.org/information-library/current-and-future-ge neration/molten-salt-reactors.aspx
Molten salt reactors (MSRs) use molten fluoride salts as primary coolant, at low pressure. This itself is not a radical departure when the fuel is solid and fixed. But extending the concept to dissolving the fissile and fertile fuel in the salt certainly represents a leap in lateral thinking relative to nearly every reactor operated so far. However, the concept is not new, as outlined below.MSRs may operate with epithermal or fast neutron spectrums, and with a variety of fuels. Much of the interest today in reviving the MSR concept relates to using thorium (to breed fissile uranium-233), where an initial source of fissile material such as plutonium-239 needs to be provided. There are a number of different MSR design concepts, and a number of interesting challenges in the commercialisation of many, especially with thorium.The salts concerned as primary coolant, mostly lithium-beryllium fluoride and lithium fluoride, remain liquid without pressurization from about 500°C up to about 1400°C, in marked contrast to a PWR which operates at about 315°C under 150 atmospheres pressure.The main MSR concept is to have the fuel dissolved in the coolant as fuel salt, and ultimately to reprocess that online. Thorium, uranium, and plutonium all form suitable fluoride salts that readily dissolve in the LiF-BeF2 (FLiBe) mixture, and thorium and uranium can be easily separated from one another in fluoride form. Batch reprocessing is likely in the short term, and fuel life is quoted at 4-7 years, with high burn-up. Intermediate designs and the AHTR have fuel particles in solid graphite and have less potential for thorium use.Graphite as moderator is chemically compatible with the fluoride salts.BackgroundDuring the 1960s, the USA developed the molten salt breeder reactor concept at the Oak Ridge National Laboratory, Tennessee (built as part of the wartime Manhattan Project). It was the primary back-up option for the fast breeder reactor (cooled by liquid metal) and a small prototype 8 MWt Molten Salt Reactor Experiment (MSRE) operated at Oak Ridge over four years to 1969 (the MSR program ran 1957-1976). In the first campaign (1965-6Cool, uranium-235 tetrafluoride (UF4) enriched to 33% was dissolved in molten lithium, beryllium and zirconium fluorides at 600-700°C which flowed through a graphite moderator at ambient pressure. The fuel comprised about one percent of the fluid.The coolant salt in a secondary circuit was lithium + beryllium fluoride (FLiBe).* There was no breeding blanket, this being omitted for simplicity in favour of neutron measurements.* Fuel salt melting point 434°C, coolant salt melting point 455°C. See Wong & Merrill 2004 reference.The original objectives of the MSRE were achieved by March 1965, and the U-235 campaign concluded. A second campaign (1968-69) used U-233 fuel which was then available, making MSRE the first reactor to use U-233, though it was imported and not bred in the reactor. This program prepared the way for building a MSR breeder utilising thorium, which would operate in the thermal (slow) neutron spectrum.According to NRC 2007, the culmination of the Oak Ridge research over 1970-76 resulted in a MSR design that would use LiF-BeF2-ThF4-UF4 (72-16-12-0.4) as fuel. It would be moderated by graphite with a four-year replacement schedule, use NaF-NaBF4 as the secondary coolant, and have a peak operating temperature of 705°C.The R&D program demonstrated the feasibility of this system, albeit excluding online reprocessing, and highlighted some unique corrosion and safety issues that would need to be addressed if constructing a larger pilot MSR with fuel salt. Challenges would include processing facilities to remove the main fission products, though gaseous fission products come off readily in the gas purge system. It also showed that breeding required a different design, with a larger blanket loop and two fluids (heterogeneous). Tritium production was a problem (see below re lithium enrichment).In 1980 Oak Ridge published a study to "examine the conceptual feasibility” of a denatured MSR (DMSR) fuelled with low-enriched uranium-235 “and operated with a minimum of chemical processing," solely as a burner reactor. The main priority was proliferation resistance, avoiding use of HEU.In the UK a large (2.5 GWe) lead-cooled fast spectrum MSR (MSFR) with the plutonium fuel dissolved in a molten chloride salt was designed, with experimental work undertaken over 1968-73. Funding ceased in 1974.There is now renewed interest in the MSR concept in Japan, Russia, China, France and the USA, and one of the six Generation IV designs selected for further development is the MSR in two distinct variants, the molten salt fast reactor (MSFR) and the advanced high temperature reactor (AHTR) – also known as the fluoride salt-cooled high-temperature reactor (FHR) with solid fuel, or PB-FHR specifically with pebble fuel. The Generation IV international Forum (GIF) mentions 'salt processing' as a technology gap for MSRs, putting the initial focus clearly on burners rather than breeders.Since the 2002 Generation IV selection process, significant changes in design philosophy have taken place, according to a 2015 report by Energy Process Developments Ltd (EPD). The first is to design simpler, less ambitious, molten salt reactors that do not breed new fuel, do not require online fuel reprocessing and which use the well-established enriched uranium fuel cycle. In this regard, both American researchers and the China Academy of Sciences/SINAP are working on solid fuel, salt-cooled reactor technology as a realistic first step into MSRs. In 2014, as part of an assessment of MSR activity internationally, proposals were made for pilot-scale implementation, where technical readiness was claimed. Six such specific proposals* were assessed over 12 months with commissioned expertise from established UK nuclear engineering firms. These proposals were all seen as credible for building a prototype, with one emerging in the EPD report as currently most suitable as a basis for UK MSR development, the Moltex SSR.* from Flibe Energy, ThorCon, Moltex, Seaborg Technologies, Terrestrial Energy and Transatomic Power.FunctionIn the normal or basic MSR concept, the fuel is a molten mixture of lithium and beryllium fluoride (FLiBe) salts with dissolved low-enriched uranium (U-235 or U-233) fluorides (UF4). The core consists of unclad graphite moderator arranged to allow the flow of salt at about 700°C and at low pressure. Much higher temperatures are possible but not yet tested. Heat is transferred to a secondary salt circuit and thence to steam or process heat. The basic design is not a fast neutron reactor, but with some moderation by the graphite is epithermal (intermediate neutron speed) and breeding ratio is less than 1.However, this concept, with fuel dissolved in the salt, is further from commercialisation than solid fuel designs, where the ceramic fuel may be set in prisms, plates, or pebbles, or one design with liquid fuel in static tubes. Reprocessing that fuel salt online is even further from commercialization.Considering liquid-fuel MSR designs, thorium can be dissolved with the uranium in a single fluid MSR, known as a homogeneous design. Two-fluid, or heterogeneous MSRs, would have fertile salt containing thorium in a second loop separate from the fuel salt containing fissile uranium or plutonium and could operate as a breeder reactor (MSBR). Here, the U-233 is progressively removed* and transferred to the primary circuit. However, graphite degradation from neutron flux limits the useful life of the reactor core with the fuel and breeding fluids in close juxtaposition, and in the 1960s it was assumed that the entire reactor vessel in the two-fluid design would be replaced after about eight years.*** e.g. by bubbling fluorine through the salt so that UF6 is formed and removed as a gas. The UF6 is reduced and added to the fuel stream.** Graphite is used to slow neutrons in epithermal designs, and deteriorates in a high neutron flux environment. The rate of damage increases with temperature, which is a particular problem with MSRs at 700°C.In liquid-fuel MSR designs the fission products dissolve in the fuel salt and are ideally removed continuously in an adjacent online reprocessing loop and replaced with fissile uranium, plutonium and other actinides or, potentially, fertile Th-232 or U-238. Meanwhile caesium and iodine in particular remain secure in the molten salt. Xenon is removed rapidly by outgassing, but protactinium-233 is a problem with thorium as a fuel source. (It is an intermediate product in producing U-233 and is a major neutron absorber.) Constant removal of fission products means that a much higher fuel burn-up could be achieved (> 50%) and the removal of fission products means less decay heat to contend with after reactor shutdown. Actinides are fully recycled and remain in the reactor until they fission or are converted to higher actinides which do so. Hence fissile plutonium is largely consumed, and contributes significant energy. The high-level waste would comprise fission products only, hence with shorter-lived radioactivity.Compared with solid-fuelled reactors, MSR systems with circulating fuel salt are claimed to have lower fissile inventories*, no radiation damage constraint on fuel burn-up, no requirement to fabricate and handle solid fuel or solid used fuel, and a homogeneous isotopic composition of fuel in the reactor. Actinides are less-readily formed from U-233 than in fuel with atomic mass greater than 235. These and other characteristics may enable MSRs to have unique capabilities and competitive economics for actinide burning and extending fuel resources. Safety is high due to passive cooling up to any size. Also, several designs have freeze plugs so that if excessive temperatures are reached, the primary salt will be drained by gravity away from the moderator into dump tanks configured to prevent criticality.* In particular, a small inventory of weapons-fissile material (Pu-242 being the dominant Pu isotope remaining), and low fuel use (the French self-breeding variant claims 50kg of thorium and 50kg U-238 per billion kWh).MSRs have large negative temperature and void coefficients of reactivity, and are designed to shut down due to expansion of the fuel salt as temperature increases beyond design limits. The negative temperature and void reactivity coefficients passively reduce the rate of power increase in the case of an inadvertent control rod withdrawal (technically known as a ‘reactivity insertion’). When tests were made on the MSRE, a control rod was intentionally withdrawn during normal reactor operations at full power (8 MWt) to observe the dynamic response of core power. Such was the rate of fuel salt thermal expansion that reactor power levelled off at 9 MWt without any operator intervention.The MSR thus has a significant load-following capability where reduced heat abstraction through the boiler tubes leads to increased coolant temperature, or greater heat removal reduces coolant temperature and increases reactivity. Primary reactivity control is using the secondary coolant salt pump or circulation which changes the temperature of the fuel salt in the core, thus altering reactivity due to its strong negative reactivity coefficient. The MSR works at near atmospheric pressure, eliminating the risk of explosive release of volatile radioactive materials.One MSR developer, Moltex, has put forward a molten salt heat storage concept (GridReserve) to enable the reactor to supplement intermittent renewables. Hot nitrate salt at about 600°C is transferred to storage tanks which are able to hold eight hours of reactor output at 2.5 GW thermal (as used in solar CSP plants). The heat store is said to add only £3/MWh to the levelised cost of electricity.In the MSBR, the reactor-grade U-233 bred in the secondary circuit needs to be removed, or it will fission there and contaminate that circuit with ‘hot’ fission products. Therefore in practice the protactinium (Pa-233) formed from the thorium needs to be removed before it decays to U-233*, but this process is unproven at any scale. It is relatively easy to remove the U-233 from the Pa-233 by fluorination to UF6 before reducing it to UF4 for adding to the primary fuel salt circuit. However, the U-233 is contaminated with up to 400 ppm U-232 which complicates processing, due to its highly gamma-active decay progeny.* Th-232 gains a neutron to form Th-233, which soon beta decays (half-life 22 minutes) to protactinium-233. The Pa-233 (half-life of 27 days) decays into U-233. Some U-232 is also formed via Pa-232 along with Th-233, and a decay product of this is very gamma active.MSRs would normally operate at much higher temperatures than LWRs – up to at least 700°C, and hence have potential for process heat. Up to this temperature, satisfactory structural materials are available. ‘Alloy N’ is a nickel-based alloy (Ni-Cr-Mo-Si) developed at ORNL specifically for MSRs with fluoride salts.Primary and secondary cooling, the fluoride saltsFluoride salts have very low vapour pressure even at red heat, carry more heat than the same volume of water, have reasonably good heat transfer properties, are not damaged by radiation, do not react violently with air or water, and are inert to some common structural metals. However having the fuel in solution also means that the primary coolant salt becomes radioactive, complicating maintenance procedures, and the chemistry of the salt must be monitored closely to maintain a chemically reduced state to minimise corrosion. Also the beryllium in the salt is toxic, which leads to at least one design avoiding it, though this requires higher temperatures to keep LiF liquid. LiF however can carry a higher concentration of uranium than FLiBe, allowing less enrichment. There are difficulties with plutonium and other TRU fluorides in fluoride solvents.Lithium used in the salt must be fairly pure Li-7, since Li-6 produces tritium when (readily) fissioned by neutrons. Li-7 has a very small neutron cross-section (0.045 barns). This means that lithium must be enriched beyond its natural 92.5% Li-7 level to minimise tritium production. Lithium-7 is being produced at least in Russia and possibly China today as a by-product of enriching lithium-6 to produce tritium for thermonuclear weapons. See also Lithium paper.LiF is exceptionally stable chemically, and the LiF-BeF2 mix ('FLiBe')* is eutectic (at 459°C it has a lower melting point than either ingredient – LiF is about 500°C). It boils at 1430°C. It is favoured in MSR and AHTR primary cooling and when uncontaminated has a low corrosion effect. The three nuclides (Li-7, Be, F) are among the few to have low enough thermal neutron capture cross-sections not to interfere with fission reactions.* Approx. 2:1 molar, hence sometimes represented as Li2BeF4. LiF without the toxic beryllium solidifies at about 500°C and boils at about 1200°C. FLiNaK (LiF-NaF-KF) is also eutectic and solidifies at 454°C and boils at 1570°C. It has a higher neutron cross-section than FLiBe or LiF but can be used in intermediate cooling loops. Sodium-beryllium fluoride (BeF2-NaF) solidifying at 385°C is used as fuel salt in one design for cost reasons.The hot molten salt in the primary circuit can be used with secondary salt circuit or secondary helium coolant generating power via the Brayton cycle as with HTR designs, with potential thermal efficiencies of 48% at 750°C to 59% at 1000°C, or simply with steam generators. In industrial applications molten fluoride salts (possibly simply cryolite – Na-Al fluoride) are a preferred interface fluid in a secondary circuit between the nuclear heat source and any chemical plant. The aluminium smelting industry provides substantial experience in managing them safely.Most secondary coolant salts do not use lithium, for cost reasons. ZrF4-NaF-KF, ZrF4-KF, NaF-BeF2 eutectic mixes are usual, as well as LiF-NaF-KF (FLiNaK).In the secondary cooling circuit of the AHTR concept, air is compressed, heated, flows through gas turbines producing electricity, enters a steam recovery boiler producing steam that produces additional electricity, and exits to the atmosphere. Added peak power can be produced by injecting natural gas (or hydrogen in the future) after nuclear heating of the compressed air to raise gas temperatures and plant output, giving it rapidly variable output (of great value in grid stability and for peak load demand where renewables have significant input). This is described as an air Brayton combined-cycle (ABCC) system in secondary circuit.In the 1960s MSRE, an alternative secondary coolant salt considered was 8% NaF + 92% NaF-BeF2 with melting point 385°C, though this would be more corrosive.Chloride salts, fast spectrum reactorsChloride salts have some attractive features compared with fluorides, in particular the actinide trichlorides form lower melting point solutions and have higher solubility for actinides so can contain significant amounts of transuranic elements. PuCl3 in NaCl has been well researched. While NaCl has good nuclear, chemical and physical properties, its high melting point means it needs to be blended with MgCl2 or CaCl2, the former being preferred in eutectic, and allowing the addition of actinide trichlorides. The major isotope of chlorine, Cl-35 gives rise to Cl-36 as an activation product – a long-lived energetic beta source, so Cl-37 is much preferable in a reactor.A British design contains the chloride fuel salt in vertical tubes and relies on convection to circulate the secondary salt coolant, which is a fluoride mix.Fast spectrum MSRs (MSFRs) can have conversion ratios ranging from burner to converter to breeder. This may be within a single unit as the ratio of U-238 to transuranics (TRU) is varied – less U-238 giving more fission. They can be optimised for burning minor actinides, for breeding plutonium from U-238, or they may be open-cycle power plants without heavy metal separation from fission products. The fast neutron spectrum allows the possibility of not having onsite processing to remove TRUs. While fission products have relatively large neutron capture cross sections in the thermal energy range, the capture cross sections at higher energies is much lower, allowing much greater fission product build-up in an MSFR than in a thermal-spectrum MSR (gaseous fission products separate out of the liquid fuel). Eventually the fuel salt heavily loaded with fission products can be sent occasionally for batch processing or allowed to solidify and be disposed of in a repository. For full breeder configuration the fissile material needs to be progressively removed.
MSFRs have a negative void coefficient in the salt and a negative thermal reactivity feedback, so can maintain a high power density with passive safety. Freeze plugs to drain the fuel salt are a further passive safety measure as in other MSRs.MSR research emphasisAmerican researchers and the China Academy of Sciences/SINAP are working primarily on solid fuel MSR technology. The main reason is that this is a realistic first step. In China this is focused on thorium-fuelled versions (see TMSR in China's dual program section below). The technical difficulty of using molten salts is significantly lower when they do not have the very high activity levels associated with them bearing the dissolved fuels and wastes. The experience gained with component design, operation, and maintenance with clean salts makes it much easier then to move on and consider the use of liquid fuels, while gaining several key advantages from the ability to operate reactors at low pressure and deliver higher temperatures. In the Generation IV program for the MSR, collaborative R&D is pursued by interested members under the auspices of a provisional steering committee. There will be a long lead time to prototypes, and the R&D orientation has changed since the project was set up, due to increased interest. It now has two baseline concepts:
The Molten Salt Fast Neutron Reactor (MSFR), which will take in thorium fuel cycle, recycling of actinides, closed Th/U fuel cycle with no U enrichment, with enhanced safety and minimal wastes. it is a liquid-fuel design.
The Advanced High-Temperature Reactor (AHTR) – also known as the fluoride salt-cooled high-temperature reactor (FHR) – with the same graphite and solid fuel core structures as the VHTR and molten salt as coolant instead of helium, enabling power densities 4 to 6 times greater than HTRs and power levels up to 4000 MWt with passive safety systems. A 5 MWt prototype is under construction at Shanghai Institute of Nuclear Applied Physics (SINAP, under the China Academy of Sciences) with 2015 target for operation.
The GIF 2014 Roadmap said that a lot of work needed to be done on salts before demonstration reactors were operational, and suggested 2025 as the end of the viability R&D phase. Russia's Molten Salt Actinide Recycler and Transmuter (MOSART) is a fast reactor fuelled only by transuranic (TRU) fluorides from uranium and MOX LWR used fuel. It is part of the MARS project (minor actinide recycling in molten salt) involving RIAR, Kurchatov and other research organisations. The 2400 MWt design has a homogeneous core of Li-Na-Be or Li-Be fluorides without a graphite moderator and has reduced reprocessing compared with the original US design. Thorium may also be used, though it is described as a burner-converter rather than a breeder. The SAMOFAR (Safety Assessment of the Molten Salt Fast Reactor) project, based in the Netherlands and funded by the European Commission, aims to prove the safety concepts of the MSFR in breeding mode from thorium. It plans advanced experimental and numerical techniques, to deliver a breakthrough in nuclear safety and optimal waste management, and to create a consortium of stakeholders. "The use of the Th-U fuel cycle is of particular interest to the MSR, because this reactor is the only one in which the Pa-233 can be stored in a hold-up tank to let it decay to U-233." The SAMOFAR consortium consists of 11 participants and is mainly undertaken by universities and research laboratories such as CNRS, JRC, CIRTEN, TU Delft and PSI, thereby exploiting each other’s expertise and infrastructure. It commenced in 2015. China's dual program China plans for the TMSR-SF to be an energy solution for the northwest half of the country, with lower population density and little water. The application of water-free cooling in arid regions is envisaged from about 2025. The China Academy of Sciences in January 2011 launched an R&D program on LFTRs, known there as the thorium-breeding molten-salt reactor (Th-MSR or TMSR), and claimed to have the world's largest national effort on it, hoping to obtain full intellectual property rights on the technology. The TMSR Centre at Shanghai Institute of Applied Physics (SINAP, under the Academy) at Jiading is responsible. In the 1970s SINAP worked towards building a 25 MWe MSR, but this endeavor gave way to the Qinshan PWR project. SINAP has two streams of TMSR development – solid fuel (TRISO in pebbles or prisms/blocks) with once-through fuel cycle, and liquid fuel (dissolved in fluoride coolant) with reprocessing and recycle. A third stream of fast reactors to consume actinides from LWRs is planned. The aim is to develop both the thorium fuel cycle and non-electrical applications in a 20-30 year timeframe.
The TMSR-SF stream has only partial utilization of thorium, relying on some breeding as with U-238, and needing fissile uranium input as well. It is optimized for high-temperature based hybrid nuclear energy applications. SINAP aimed at a 2 MW pilot plant initially, though this has been superseded by a simulator (TMSR-SF0) to be followed by a 10 MWt prototype (TMSR-SF1) before 2025. A 100 MWt demonstration pebble bed plant (TMSR-SF2) with open fuel cycle would follow, then a 1 GW demonstration plant (TMSR-SF3). TRISO particles will be with both low-enriched uranium and thorium, separately.
The TMSR-LF stream claims full closed Th-U fuel cycle with breeding of U-233 and much better sustainability with thorium but greater technical difficulty. It is optimized for utilization of thorium with electrometallurgical pyroprocessing. SINAP aims for a 2 MWt pilot plant (TMSR-LF1) initially, then a 10 MWt experimental reactor (TMSR-LF2) by 2025, and a 100 MWt demonstration plant (TMSR-LF3) with full electrometallurgical reprocessing by about 2035, followed by 1 a GW demonstration plant. The TMSR-LF timeline is about ten years behind the SF one.
A TMSFR-LF fast reactor optimized for burning minor actinides is to follow.
SINAP sees molten salt fuel being superior to the TRISO fuel in effectively unlimited burn-up, less waste, and lower fabricating cost, but achieving lower temperatures (600°C+) than the TRISO fuel reactors (1200°C+). Near-term goals include preparing nuclear-grade ThF4 and ThO2 and testing them in a MSR. It appears that the postponement of building the 2 MW test reactor may be due to inadequate supplies of pure lithium-7. The TMSR-SF program is proceeding with preliminary engineering design in cooperation with the Nuclear Power Institute of China (NPIC) and Shanghai Nuclear Engineering Research & Design Institute (SNERDI). Nickel-based alloys are being developed for structures, along with very fine-grained graphite. Two methods of tritium stripping are being evaluated, and also tritium storage. The 10 MWt TMSR-SF1 will have TRISO fuel in 60mm pebbles, similar to HTR-PM fuel, and deliver coolant at 650°C and low pressure. Primary coolant is FLiBe (with 99.99% Li-7) and secondary coolant is FLiNaK. Core height is 3 m, diameter 2.85 m, in a 7.8 m high and 3 m diameter pressure vessel. Residual heat removal is passive, by cavity cooling. A 20-year operating life is envisaged. The TMSR-SF0 simulator is one-third scale, with FLiNaK cooling and a 400 kW electric heater. The 2 MWt TMSR-LF1 is only at the conceptual design stage, but it will use fuel enriched to under 20% U-235, have a thorium inventory of about 50 kg and conversion ratio of about 0.1. FLiBe with 99.95% Li-7 would be used, and fuel as UF4. The project would start on a batch basis with some online refuelling and removal of gaseous fission products, but discharging all fuel salt after 5-8 years for reprocessing and separation of fission products and minor actinides for storage. It would proceed to a continuous process of recycling salt, uranium and thorium, with online separation of fission products and minor actinides. It would work up from about 20% thorium fission to about 80%. Beyond these, a 373 MWt/168 MWe liquid-fuel MSR small modular reactor is planned, with supercritical CO2 cycle in a tertiary loop at 23 MPa using Brayton cycle, after a radioactive isolation secondary loop. Various applications as well as electricity generation are envisaged. It would be loaded with 15.7 tonnes of thorium and 2.1 tonnes of uranium (19.75% enriched), with one kilogram of uranium added daily, and have 330 GWd/t burn-up with 30% of energy from thorium. Online refuelling would enable eight years of operation before shutdown, with the graphite moderator needing attention. The US Department of Energy is collaborating with the China Academy of Sciences on the program, which had a start-up budget of $350 million. TMSR commercial deployment is anticipated in the 2030s. Other solid- or fixed-fuel types AHTR / FHR Research on molten salt coolant has been revived at Oak Ridge National Laboratory (ORNL) in the USA with the Advanced High Temperature Reactor (AHTR). This is a larger reactor using a coated-particle graphite-matrix fuel like that in the GT-MHR (see the information paper on Small Nuclear Power Reactors) and with molten fluoride salt as primary coolant. It is also known as the Fluoride High Temperature Reactor (FHR). While similar to the gas-cooled HTR it operates at low pressure (less than 1 atmosphere) and higher temperature, and gives better heat transfer than helium. The FLiBe salt is used solely as coolant, and achieves temperatures of 750-1000°C or more while at low pressure. This could be used in thermochemical hydrogen manufacture. As noted above, a 5 MW thorium-fuelled prototype is under construction at Shanghai Institute of Nuclear Applied Physics (SINAP, under the China Academy of Sciences) originally with a 2015 target for operation. A 100 MWt demonstration pebble bed plant with open fuel cycle is planned by about 2025. SINAP sees this design as having potential for higher temperatures than MSRs with fuel salt. A small version of the AHTR/FHR is the SmAHTR, with 125 MWt size-matched to early process heat markets, or producing 50+MWe. The operating temperature is 700°C with FLiBe primary coolant and three integral heat exchangers. It is truck transportable, being 9m long and 3.5m diameter. Fuel is 19.75% enriched uranium in TRISO particles in graphite blocks or fuel plates. The refuelling interval is 2.5 to 4 years depending on fuel configuration. Secondary coolant is FLiNaK to Brayton cycle, and for passive decay heat removal, separate auxiliary loops go to air-cooled radiators. Later versions are intended to reach 850° to 1000°C, using materials yet to be developed. In the USA a consortium including UC Berkeley, ORNL and Westinghouse is designing a 100 MWe pebble bed FHR, with annular core. It is designed for modular construction, and from 100 MWe base-load is able to deliver 242 MWe with gas co-firing for meeting peak loads. Fuel pebbles are 30 mm diameter, much less than gas-cooled HTRs. A 410 MWe/900 MWt pebble bed version was also being designed with UC-Berkeley. AHTR reactor sizes of 1500 MWe/3600 MWt are envisaged, with capital costs estimated at less than $1000/kW. In the secondary cooling circuit, air is compressed, heated, flows through gas turbines producing electricity, enters a steam recovery boiler producing steam that produces additional electricity, and exits to the atmosphere. Added peak power can be produced by injecting natural gas (or hydrogen in the future) after nuclear heating of the compressed air to raise gas temperatures and plant output, giving it rapidly variable output (of great value in grid stability and for peak load demand where renewables have significant input). This is described as an air Brayton combined-cycle (ABCC) system in secondary circuit. Moltex SSR Moltex Energy's Stable Salt Reactor (SSR) is a conceptual UK reactor design that, like all conventional reactors in operation, relies on convection from static vertical fuel tubes in the core to convey heat to the reactor coolant. Because the nuclear material is contained in fuel assemblies, standard industrial pumps can be used for the low radioactivity coolant salt. Core temperature is 500-600°C, at atmospheric pressure. Decay heat is removed by natural air convection. Fuel tubes of nickel-chromium alloy three-quarters filled with the molten fuel salt (60% NaCl, 40% Pu, U & lanthanide trichlorides) are grouped into fuel assemblies which are similar to those used in standard reactors and use similar structural materials. The individual fuel tubes are vented so that fission product gases escape into the coolant salt, which is a NaF-KF-ZrF4 mix (Li-7 fluoride is avoided for cost reasons). The assemblies can be moved laterally without removing them. Refuelling is thus continuous online, and after five years depleted assemblies are stored at one side of the pool pending reprocessing. The primary fissile fuel in the original fast reactor version is plutonium-239 chloride with minor actinides and lanthanides recovered from LWR fuel or from its 'global workhorse reactor', though with 12% Pu quoted in one report. A 150 MWe pilot module is envisaged. It will have increased relevance if the UK government decides to commission it to help burn the UK's stockpile of plutonium. Commercial plants of 1000 MWe are envisaged. Overnight capital cost is estimated at about £1400 per kW. The company then announced a ‘global workhorse' version of its design as 40 MWe modules running on LEU fluorides with "graphite built into the fuel assemblies" and thermal neutron spectrum. A thorium breeder version will use thorium as a fuel source. In this, thorium is in the coolant salt and the U-233 produced is progressively dissolved in bismuth at the bottom of the salt pool. This contains U-238 to denature it. Once the desired level of U-233 is achieved, the bismuth with uranium is taken out batch-wise, and the mixed-isotope uranium is chlorinated to become fuel. If the fuel is used in a fast reactor, plutonium and actinides can be added. The fuel assemblies are arranged at the centre of a tank half filled with the coolant salt which transfers heat away from the fuel assemblies to the peripheral steam generators, essentially by convection. The fuel assemblies are held in place by gravity in fittings set in the base of the tank, which is at atmospheric pressure. Moltex has also put forward its GridReserve molten salt heat storage concept to enable the reactor to supplement intermittent renewables. Other liquid-fuel types: two-fluid breeders Liquid fluoride thorium reactor The liquid fluoride thorium reactor (LFTR) is a heterogeneous MSR design which breeds its U-233 fuel from a fertile blanket of lithium-beryllium fluoride (FLiBe) salts with thorium fluoride. The thorium-232 captures neutrons from the reactor core to become protactinium-233, which decays (27-day half-life) to U-233. It may be possible to separate Pa-233 on-line and let it decay to U-233. Otherwise, newly-formed U-233 forms soluble uranium tetrafluoride (UF4), which is converted to gaseous uranium hexafluoride (UF6) by bubbling fluorine gas through the salt (which does not chemically affect the less-reactive thorium tetrafluoride). The volatile uranium hexafluoride is captured, reduced back to soluble UF4 by hydrogen gas, and finally is added to the FLiBe core to serve as fissile fuel. A complication is that traces of U-232 are formed, reporting with the U-233, and having highly gamma-active decay progeny. LFTRs can rapidly change their power output, and hence be used for load-following. Because they are expected to be inexpensive to build and operate, 100 MWe LFTRs could be used as peak and back-up reserve power units. Flibe LFTR Flibe Energy in the USA is studying a 40 MW two-fluid graphite-moderated thermal reactor concept based on the 1970s MSRE. It uses lithium fluoride/beryllium fluoride (FLiBe) salt as its primary coolant in both circuits. This is based on earlier US work on the molten salt reactor program. Fuel is uranium-233 bred from thorium in FLiBe blanket salt. Fuel salt circulates through graphite logs. Secondary loop coolant salt is sodium-beryllium fluoride (BeF2-NaF). A 2 MWt pilot plant is envisaged, and eventually 2225 MWt commercial plants. Other liquid fuel types: single-fluid, thermal spectrum Integral MSR Canada-based Terrestrial Energy Inc (TEI) has designed the Integral MSR. This simplified MSR integrates the primary reactor components, including primary heat exchangers to secondary clean salt circuit, in a sealed and replaceable core vessel that has a projected life of seven years. The IMSR will operate at 600-700°C, which can support many industrial process heat applications. It operates in the thermal neutron spectrum with a hexagonal arrangement of graphite elements forming the moderator. The fuel-salt is a eutectic of low-enriched (2-4%) uranium-235 fuel (as UF4) and a fluoride carrier salt – likely sodium rubidium fluoride with potential to change to FLiBe – at atmospheric pressure. Secondary loop coolant salt is ZrF4-KF. Multiple pumps and six heat exchangers allow for redundancy. Emergency cooling and residual heat removal are passive. When the sealed core is replaced after seven years, it is then left for fission products to decay. Each plant would have space for two reactors, allowing seven-year changeover, with the used unit removed for off-site reprocessing when it has cooled. The IMSR is designed in three sizes: 80 MWth (32.5 MWe), 300 MWth, and 600 MWth. The total levelized cost of electricity from the largest is projected to be competitive with natural gas. The smallest is designed for off-grid, remote power applications, and as a prototype. The company expects to complete CNSC pre-licence review by the end of 2016, and hopes to commission its first commercial reactor by the early 2020s. In January 2015 the company announced a collaborative agreement with US Oak Ridge National Laboratory (ORNL) to advance the design. Transatomic TAP Transatomic Power Corp is a new US company partly funded by Founders Fund and aiming to develop a single-fluid MSR using very low-enriched uranium fuel (1.8%) or the entire actinide component of used LWR fuel. The TAP reactor has an efficient zirconium hydride* moderator and a LiF-based fuel salt bearing the UF4 and actinides, hence a very compact core. The secondary coolant is FLiNaK salt (LiF-KF-NaF) to a steam generator. * as used in TRIGA research reactors and TOPAZ and SNAP reactors for space program. Owing to the ZrH moderator, there are significantly more neutrons in the thermal region (less than 1 eV) compared with a graphite moderator, thereby enabling the reactor to generate power from very low-enriched uranium or used LWR fuel. The epithermal (1 eV - 1 MeV) spectrum is lower than that with graphite, but in the fast spectrum (over 1 MeV) the neutron flux is greater than with graphite moderator, and therefore contributes strongly to actinide burning. It would give up to 96% actinide burn-up. Fission products are mostly removed batch-wise and fresh fuel added. In addition to negative void and thermal coefficients, the moderator starts to fail at higher temperatures due to hydrogen loss. Decay heat removal can be by convection. After a 20 MWt demonstration reactor, the envisaged first commercial plant will be 1250 MWt/550 MWe running at 44% thermal efficiency with 650°C in primary loop, using steam cycle. The overnight cost for an nth-of-a-kind 550 MWe plant, including lithium-7 inventory and on-line fission product removal and storage, is estimated at $2 billion with a three-year construction schedule. A version of the reactor may utilize thorium fuel. Fuji MSR The Fuji MSR is a 100-200 MWe graphite-moderated design to operate as a near-breeder and was being developed internationally by a Japanese, Russian and US consortium: the International Thorium Molten Salt Forum (ITMSF). It is based on the Oak Ridge MSBR, and several variants have been designed, including a 10 MWe mini Fuji. Thorium Tech Solutions Inc (TTS) plan to commercialise the Fuji concept, and is working on it with the Halden test reactor in Norway. Thorcon Martingale in the USA is designing the ThorCon MSR, which is a 250 MWe scaled-up Oak Ridge MSRE. It is a single-fluid thorium converter reactor in the thermal spectrum, graphite moderated. It uses a combination of U-233 from thorium and U-235 enriched from mined uranium. Fuel salt is sodium-beryllium fluoride (BeF2-NaF) with dissolved uranium and thorium tetrafluorides (Li-7 fluoride is avoided for cost reasons). Secondary loop coolant salt is also sodium-beryllium fluoride. It operates at 700°C. There is no on-line processing – this takes place in a centralized plant at the end of the core life, with off-gassing of some fission products meanwhile. A pilot plant would be similar to the mini Fuji. Martingale aims for an operating prototype by 2020, with modular construction. Several 550 MWt units would comprise a power station, and a 1000 MWe Thorcon plant would comprise about 200 factory- or shipyard-build modules installed below grade (30 m down). All components are deigned to be easily and frequently replaced. For instance, every four years the entire primary loop would be changed out, returned to a centralized recycling facility, decontaminated, disassembled, inspected, and refurbished. Incipient problems would be rectified and major upgrades could be introduced without significantly disrupting power generation. The company claims generation costs of 3 to 5 c/kWh depending on scale, and is "targeting its first installations in forward-looking countries that support technology-neutral nuclear regulations and see the benefits of the license-by-test process." Seaborg Waste Burner – SWaB Seaborg Technologies in Denmark has a thermal-epithermal single fluid reactor design for 50 MWt pilot unit with a view to 250 MWt commercial modular units fuelled by spent LWR fuel and thorium. Fuel salt is Li-7 fluoride with thorium, plutonium and minor actinides as fluorides. This is pumped through the graphite column core and heat exchanger. Fission products are extracted on-line. Secondary coolant salt is FLiNaK, at 700°C. Spent LWR fuel would have the uranium extracted for recycle, leaving Pu and minor actinides to become part of the MSR fuel, with thorium. Other liquid fuel types: single-fluid, fast spectrum Southern Co, MCFR Southern Company Services in the USA is developing a molten chloride fast reactor (MCFR) with TerraPower, Oak Ridge National Laboratory (ORNL) – which hosts the work, the Electric Power Research Institute (EPRI) and Vanderbilt University. No details are available, and it is not certain that it is a single-fluid type. However, fuel is in the chloride salt (see section above) and as a fast reactor it can burn U-238, actinides and thorium as well as used light water reactor fuel, requiring no enrichment apart from the initial fuel load (these details from TerraPower, not Southern). It is reported to be large. In January 2016 the US DOE awarded a Gateway for Accelerated Innovation in Nuclear (GAIN) grant to the project, worth up to $40 million. In August 2016 Southern Nuclear Operating Company signed an agreement to work with X-energy to collaborate on development and commercialization of their respective small reactor designs. With TerraPower and ORNL, X-energy is designing the Xe-100 pebble-bed HTR of 48 MWe. Elysium MCSFR Elysium Industries in the USA and Canada have the 1000 MWe Molten Chloride Salt Fast Breeder Reactor (MCSFR) design with fuel in the chloride salt. It operates below grade at near atmospheric pressure and uses no water near the fuel salt. It is designed to load-follow. Used fuel from light water reactors or depleted uranium with some plutonium can fuel it. Selected fission products are removed online. Passive safety includes a freeze plug. It has negative temperature and void coefficients. References Ho M.K.M., Yeoh G.H., & Braoudakis G., 2013, Molten Salt Reactors, in Materials and processes for energy: communicating current research and technological developments, ed A.Mendez-Vilas, Formatex Research Centre Merle-Lucotte, E. et al 2009, Minimising the fissile inventory of the Molten Salt Fast Reactor, Advances in Nuclear Fuel Management IV (ANFM 2009), American Nuclear Society Merle-Lucotte, E. et al 2007, The Thorium molten salt reactor: launching the thorium cycle while closing the current fuel cycle, ENC 2007 Forsberg, C.W., Peterson, P.F., Zhao, H.H. 2004, An advanced molten salt reactor using high-temperature reactor technology, American Nuclear Society LeBlanc, D, 2009, Molten Salt Reactors: a new beginning for an old idea, Nuclear Engineering & Design 2010, Elsevier Transatomic Power Corp., technical white paper, March 2014 Ignatiev, V & Feynberg, O, Kurchatov Inst, Molten Salt Reactor: overview and perspectives, OECD 2012 Appendix 6.0 Molten Salt Reactor, Generation IV Nuclear Energy Systems Ten-Year Program Plan – Fiscal Year 2007, Department of Energy Office of Nuclear Energy (September 2007) Hargraves, R & Moir, R, 2010, Liquid Fluoride Thorium Reactors, American Scientist 98 Fluoride-Salt-Cooled High-Temperature Reactors (FHRs) for Base-Load and Peak Electricity, Grid Stabilization, and Process Heat, Forsberg, Hu, Peterson, Sridharan, 2013, MIT Wong, C & Merrill, B, 2004, Relevant MSRE and MSR Experience, ITER TBM Project Meeting at UCLA, 23-25 February 2004 Energy Process Developments Ltd, July 2015, MSR Review: Feasibility of Developing a Pilot Scale Molten Salt Reactor in the UK, July 2015. Sherrell Greene, Oak Ridge National Laboratory, SmAHTR – the Small Modular Advanced High Temperature Reactor (September 2010) Xu, Hongjie, SINAP, Status and Perspective of TMSR in China, presented at the Generation IV International Forum (GIF) Molten Salt Reactor Workshop at the the Paul Scherrer Institute on 24 January 2017 Background, Status, and Issues Related to the Regulation of Advanced Spent Nuclear Fuel Recycle Facilities, A White Paper of the US Nuclear Regulatory Commission’s Advisory Committee on Nuclear Waste and Materials, NUREG-1909 (June 2008) Weinberg Foundation, 2014, The UK’s Forgotten Molten Salt Reactor Program Holcomb D.E. et al, July 2011, Fast Spectrum Molten Salt Reactor Options, ORNL
PostPosted: Fri Nov 09, 2018 1:01 am    Post subject: Reply with quote
Update on the Liquid Fluoride Thorium Reactor projects in China and the USA brian wang | October 11, 2016
https://www.nextbigfuture.com/2016/10/update-on-liquid-fluoride-thoriu m.html
The Liquid Fluoride Thorium Reactor is a type of Molten Salt Reactor. Molten Salt Reactors are Generation IV nuclear fission reactors that use molten salt as either the primary reactor coolant or as the fuel itself; they trace their origin to a series of experiments directed by Alvin Weinberg at Oak Ridge National Laboratory in the ‘50s and ‘60s. The LFTR is differentiated from other variants of the MSR by the fact that it runs on thorium rather than uranium, thorium being an element that is fertile rather than fissile, and which will transmute to fissile uranium-233 upon exposure to neutrons.
In 2011 the Chinese Academy of Sciences announced plans to commercialize a thorium-based MSR in 20 years (it is also developing non-thorium MSRs and solid fuel thorium reactors). The Shanghai Institute of Applied Physics has since employed 700 nuclear engineers for this project. The plan is for a 10MW pilot LFTR is expected to be operationalized in 2025, with a 100MW version set to follow in 2035.
China theoretically has enough thorium to supply all its energy for the next 20,000 years.
Shanghai Institute of Applied Physics (SINAP, under the Academy) has two streams of TMSR development – solid fuel (TRISO in pebbles or prisms/blocks) with once-through fuel cycle, and liquid fuel (dissolved in FLiBe coolant) with reprocessing and recycle. A third stream of fast reactors to consume actinides from LWRs is planned.
The TMSR-SF stream has only partial utilization of thorium, relying on some breeding as with U-238, and needing fissile uranium input as well. SINAP aims at a 2 MW pilot plant (TMSR-SF1) initially, and a 100 MWt experimental pebble bed plant (TMSR-SF2) with open fuel cycle by about 2025, then a 1 GW demonstration plant (TMSR-SF3) by 2030. TRISO particles will be with both low-enriched uranium and thorium, separately.
The TMSR-LF stream claims full closed Th-U fuel cycle with breeding of U-233 and much better sustainability with thorium but greater technical difficulty. SINAP aims for a 2 MWt pilot plant (TMSR-LF1) by 2018, a 10 MWt experimental reactor (TMSR-LF2) by 2025 and a 100 MWt demonstration plant (TMSR-LF3) with full electrometallurgical reprocessing by 2035, followed by 1 a GW demonstration plant. A TMSFR-LF fast reactor optimized for burning minor actinides is to follow.
SINAP sees molten salt fuel being superior to the TRISO fuel in effectively unlimited burn-up, less waste, and lower fabricating cost, but achieving lower temperatures (600°C+) than the TRISO fuel reactors (1200°C+). Near-term goals include preparing nuclear-grade ThF4 and ThO2 and testing them in a MSR. The US Department of Energy is collaborating with the China Academy of Sciences on the program, which had a start-up budget of $350 million. The target date for TMSR commercial deployment is 2032.
According to Flibe Energy, headed by nuclear scientist Kirk Sorensen, thorium is so energy dense that 6600 tonnes of it could replace the ‘combined 5.3 billion tonnes of coal, 31.1 billion barrels of oil, 2.92 trillion cubic meters of natural gas, and 65,000 tonnes of uranium that the world consumes annually’. It is approximately 3X more abundant in the Earth’s crust than uranium, and significant quantities have already been extracted as the by-products of existing mining operations. Most compellingly, the energy output of a LFTR, per metric ton of thorium ore, is estimated to be 200X greater than the output of a Light Water Reactor (a type of PWR).
Flibe Energy is a startup that is also trying to develop Liquid Fluoride Thorium Reactors.
PostPosted: Sat Mar 21, 2020 12:20 pm    Post subject: Reply with quote
Don’t like CO2? Advanced nuclear power is the answer
Renewable wind, solar, hydro and biofuels cannot fill the gap
https://asiatimes.com/2020/01/carbon-dioxides-scourge-advanced-nuclear -power/
by Jonathan Tennenbaum January 26, 2020
A file photo of the installation of a containment dome for a Hualong reactor at a nuclear plant in China's Guangxi province. Photo: Handout
So you don’t like CO2? What you need to know, then, is that there’s no alternative to advanced nuclear power.
Concern about the climate effects of man-caused CO2 emissions has prompted gigantic investments into so-called renewable energy sources: wind, solar, hydropower and biofuels. Meanwhile, in a huge mistake, nuclear energy – a reliable CO2-free power source producing 14% of the world’s electricity – has been left far behind.
Germany provides a bizarre example, albeit not the only one. Here the government’s commitment to its so-called climate goals has been combined, paradoxically, with the decision to shut down the country’s remaining nuclear power plants by 2022.
Would it not be more rational, if we believe that human emissions of CO2 are destroying the planet, to expand nuclear energy as quickly as possible, rather than shut it down?
Last December the influential German magazine Der Spiegel ran a story with the title, “Can New Reactor Concepts Save Us from the Climate Collapse?” The article reports on how numbers of international investors and firms, including Bill Gates and his TerraPower, are engaged in a race to develop advanced nuclear reactor technologies as the key to eliminating world dependence on fossil fuels – a goal that could never be attained by the so-called renewable sources alone.
Design of Bill Gates’s TerraPower-Hitachi versatile test reactor. illustration: US DOE
Addressing readers who remain terrified of nuclear energy, Spiegel writes: “According to estimates, 800 000 people die every year from the smoke produced by coal, containing toxic substances such as sulfur dioxide, nitrogen oxides, mercury or arsenic. But concepts must also be demonstrated for how to dispose of the toxic substances contained in used-up photovoltaic cells.”
The magazine explains that “energy generation nearly always claims victims and creates some pollutants. The question is, what costs and risks are we ready to accept? What should we fear most: global warming, which is sure to come, or a possible regional reactor catastrophe? The objections to nuclear energy are justified. But in view of climate change, is it right to reject nuclear technology altogether?”
New reactor designs such as the traveling wave reactor, the molten salt reactor and small modular reactors promise to be much safer and cheaper than conventional nuclear power and have broader ranges of applications. Some could even “burn” nuclear waste as a fuel – eliminating the need for very long-term storage of radioactive material, which is a major argument against nuclear energy. Standardized modular construction would allow nuclear reactors to be factory-produced in much shorter times.
On this basis, a massive expansion of nuclear power worldwide might be accomplished within the space of 10-15 years. The rapid build-up of nuclear power in France, in response to the 1973 “oil shock,” provides a certain historical precedent.
New agenda
There is no doubt that nuclear energy is back on the world agenda, even for many of those who have been bitterly opposed to it in the past. And nuclear energy – in the form used today – still has serious problems. But new reactor concepts are on the table, which addresses those issues and could completely redefine the role of nuclear energy in the world economy.
I shall describe some of these reactor concepts in a bit of detail. But first I should try to establish clarity on a crucial point.
I believe we are facing a branching point in global energy policy. What should be the priority? Assuming it should be a goal to drastically reduce world emissions of CO2 in the medium and long term – which I don’t want to argue about here – is it wise to invest so much in renewable energy sources, as many nations are doing today? Or should we allot only a limited role to the renewables, and go for a massive expansion of nuclear energy instead?
I will not discuss nuclear fusion in its various forms, an area of great importance for the future, but whose availability for large-scale energy generation cannot be predicted with certainty at present; nor the potentially game-changing area popularly referred to as “cold fusion” (better called “low energy nuclear reactions” or LENR). “Cold fusion” was the subject of a previous Asia Times series.
Now let’s deal in more detail with a very big question: To what extent could so-called renewable energy replace the use of fossil fuels?
According to Bloomberg New Energy Finance, $288.9 billion was invested into renewable energy in 2018, the bulk of which went into wind and solar energy. Despite this, CO2 emissions worldwide continue to grow relentlessly.
China, for example, leads the world in the size of its investments into renewable energy, with over $100 billion invested in 2018 alone. At the same time China also leads the world in the construction of new coal power plants, which are the single biggest source of CO2 emissions by human activity. Since the start of 2018, China has brought 42.9 gigawatts of new coal-fired power plants online, with another 121.3 GW under construction and 200 GW or more in various stages of planning.
India also continues to expand its coal power capacity, with 36 GW under construction. Last July the Indian power ministry’s chief engineer declared that coal-fired power generation capacity is expected to rise by 22.4% in the coming three years. The ongoing expansion of coal power in China and India does not reflect a lack of concern about pollution and climate change; the problem lies above all in the economic, physical and technical constraints under which these nations must design their energy policies.
The simple fact is, that in the foreseeable future no amount of investment into renewables, however large, will be sufficient to eliminate humans’ dependence on coal, oil and natural gas. That is, unless we are willing to collapse the world economy.
If we are really committed to reducing CO2 emissions, then there is no way around nuclear energy, and lots of it. The reasons are elementary.
Suppose that by some means we could completely eliminate the use of fossil fuels for transport and heating. This is hardly conceivable without greatly increasing the global consumption of electricity, which can already be projected to more than double over the next 25 years. Where will all the electricity come from?
If we insist on “CO2-free” sources of electricity, then the number of realistic options is small. When it comes to large-scale power production they are limited essentially to hydroelectric, wind, solar and nuclear energy. Electricity generation from biofuels, which can claim to be “CO2-neutral”, might contribute a few additional percent.
Unfortunately, economically viable hydropower is limited to certain geographical locations, and its potential for further expansion is strongly constrained by environmental, economic and social factors as well as very long lead times for large projects. Leaving these problems aside, hydroelectricity might hypothetically be increased to about three times its present level in the long term. Given the projected growth of electricity demand, the share of hydropower could at best grow from 16% today, to 25% in 2050. Where will the other 75% come from?
Wind and solar power have some obvious strong points. They require no supply of fuel and their total capacities can be expanded quickly, at relatively low unit cost, as is occurring today around the world. At the same time, wind and solar energy have a fundamental drawback: their output fluctuates depending on conditions that are outside human control. This makes it impossible to fit the output curve to the demand curve, even approximately.
Solar panels produce no electricity at all at night, of course, and not much on rainy and overcast days. The electricity output from wind power installations can fluctuate wildly even from one hour to the next, and even when averaged out over a large region. In contrast, conventional or nuclear power plants provide a continuous, steady supply of electricity, at power levels which can be precisely controlled.
Quite apart from the intermittent character of solar and wind energy, the so-called renewable energy sources all suffer from the drawback of low intrinsic power density: the renewables require vastly larger areas and/or larger numbers of operating units to reach the same output as a modern, compact coal, gas or nuclear plant.
Under typical weather conditions of central Europe, for example, it takes some thousands of large wind turbines, or solar cells covering a total area of the order of 100 square kilometers, to generate the same yearly quantity of electricity as a single 1 GW conventional or nuclear power plant. Building a wind turbine capacity of 1 GW requires 50-100 times as much steel and cement as a nuclear power plant with the same capacity.
I mentioned biogas. Electricity production from biogas could be included as “CO2-neutral” in the sense that the CO2 emitted by the combustion of biogas ultimately derives from the photosynthetic capture of atmospheric CO2 by crop plants.
The World Bioenergy Association estimates that biogas has the future potential to provide an amount of energy equivalent to about 25% of that presently generated from natural gas (in all its uses) in the world economy. If 100% of that biogas were used to produce electricity – which is highly unrealistic – this would cover about 5% of today’s electricity consumption.
Large-scale biogas production – as opposed to smaller-scale utilization of organic wastes – de facto means using agricultural crops as solar collectors. Unfortunately, photosynthesis in plants is 10 times less efficient in capturing solar energy, than modern solar cells. This makes the production and use of biofuels for large-scale electricity generation an extremely resource-intensive process, requiring large land areas, water resources, machinery, transport and labor per unit output – resources that might otherwise be applied to food production and other uses.
Jonathan Tennenbaum received his PhD in mathematics from the University of California in 1972 at age 23. Also a physicist, linguist and concert pianist, he’s a former editor of FUSION magazine. He lives in Berlin and travels frequently to Asia and elsewhere, consulting on economics, science and technology. Next in this series: the bizarre case of Germany examined.
Tagged: Bill GatesEconomyfissionfusionHydropowerSolar EnergyTechnologyTerraPowerWind power
Join the Conversation
Post new topic   Reply to topic    9/11, 7/7 & the War on Freedom Forum Index -> General All times are GMT
Page 1 of 1
